clizlee76
Feb 23, 2019Aspirant
ReadyCloud failed to upload connection problem
I'm using ReadyCloud to upload files to my ReadyNAS and used to have no problem, but now whenever I try to upload anything and to any folder, it gives me a Failed Connection Error. I can see my devic...
- Feb 24, 2019
What happens if you browse to https://nas-ip-address/admin (using the real NAS IP address of course)?
Perhaps also try downloading RAIDar, and see what status it gives for the NAS. https://kb.netgear.com/20684/ReadyNAS-Downloads
Feb 24, 2019Guru - Experienced User
Can you download files?
Did you check the admin web ui of the NAS (to confirm that your volume is ok)?
- clizlee76Feb 24, 2019Aspirant
It just tried downloading one of my files and it doesn't do anything. No error message, but no download.
When I try to access the Admin page, it says I can only access it when on the same network (LAN) as my device. My computer is connected to the same wifi but I'm not connected via ethernet cable. But the NAS is connected to the router via ethernet cable.
- StephenBFeb 24, 2019Guru - Experienced User
- jbuchalFeb 24, 2019Tutor
This really looks like a problem with ReadyCLOUD, not any particular unit. There is another thread going about inability to download. I can't contact support for my free 90 day support, because it says my new model 212 I bought through Amazon last month is the wrong country of purchase. I hope someone registered with support tries to download something soon so this can get fixed. This is not an acceptable level of reliability for cloud service.
