Titus3012
Jun 02, 2015Aspirant
Readycloud folder download
Hi guys and gals , in Readycloud i can only download file by file i want to download a hole folder . how do i do this ?
EskenderNG
Jun 02, 2015NETGEAR Employee Retired
Hello,
I believe you cannot download folders using the ReadyCLOUD website. This is most likely due to the fact that this service is browser based and browsers are not capable of downloading folders. However, you can select all files within a folder at once and download them.
If you use the ReadyCLOUD Desktop App you can easily access a share by clicking on it. This will open the Windows Explorer (assuming you are using Windows). From there you can copy folders as you would normally do.
Bye,
Eskender
Bye,
Eskender
