bgogl
Mar 05, 2018Follower
Readycloud folders dont appear
Hello, after using my readynas only in my local network at home, now i want to use the cloud service. connecting and everything works, but the folders dont appear when i select my readynas on readyc...
JohnCM_S
Mar 06, 2018NETGEAR Employee Retired
Hi bgogl,
Welcome to the Community!
You may try first leaving and then rejoining the NAS to Readycloud. Please also make sure that there is a green check mark on Internet and Service on Cloud tab of the ReadyNAS local admin page.
JohnCM_S
NETGEAR Community Team
JohnCM_S
Mar 09, 2018NETGEAR Employee Retired
Hi bgogl,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JohnCM_S
