GeorgeCRD
Dec 04, 2022Tutor
ReadyCLOUD gone after April 4th, 2023
I received this email from Netgear on 12/04/2022: "We wanted to let you know that NETGEAR is discontinuing support for the ReadyCLOUD feature on your NETGEAR router on April 4th, 2023. The ReadyCL...
Dec 05, 2022Guru - Experienced User
GeorgeCRD wrote:
"We wanted to let you know that NETGEAR is discontinuing support for the ReadyCLOUD feature on your NETGEAR router on April 4th, 2023. The ReadyCLOUD remote file access function allows you to remotely access the data on a USB storage device attached to your router.
Interesting, for some reason I didn't receive this.
GeorgeCRD wrote:
Does anyone have any suggestions on how to access files stored on a drive attached to Nighthawk X10 from the internet after 04/04/2023?
I'd start with using OpenVPN+DDNS. That should be enough for remote access (though not sharing).
One caveat - OpenVPN requires that the client phone or PC be able to connect inbound to the router. If your ISP uses carrier grade NAT, that isn't possible. Broadband internet services do use CGNAT, and some landline ISPs do also. In those cases, you could still use cloud storage solutions as suggested by Netgear.
