GeorgeCRD
Dec 04, 2022Tutor
ReadyCLOUD gone after April 4th, 2023
I received this email from Netgear on 12/04/2022: "We wanted to let you know that NETGEAR is discontinuing support for the ReadyCLOUD feature on your NETGEAR router on April 4th, 2023. The ReadyCL...
AGSowjet
Apr 18, 2023Apprentice
I am seeing a notice on the top of the screen when accessing ReadyCloud: "NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. ReadyCLOUD mobile app, desktop application, and ReadyCLOUD web portal readycloud.netgear.com will all be terminated by July 1st, 2023. After that date, you can continue to access locally your ReadyNAS, or access locally the USB drive connected to the routers, but remote access won’t be available."
The VPN method seems to me to be the best to keep remote access, since it is independent of external services and you also get full access to the admin panel of the devices, which was not even possible with ReadyCloud.
I wonder if it's possible to run the VPN server on the ReadyNAS? That would be most convenient.
