mvetri
Apr 21, 2018Guide
ReadyCloud GUI not working (Desktop App) PRJNAME
I can no longer auto connect with the Ready Cloud App for Windows. I uninstalled the app, then reinstalled, and the interface titles changed and are variable of code and the interface looks weird. ...
mvetri
Apr 26, 2018Guide
Hi Marc:
Thank you for the reply. I am actually runny ReadyCloud app on 2 WIndows 10 PCs. One is an HP the other a Dell. I verified I have the most updated versions of Java and the ReadyCloud app installed on both PCs. The ReadyCloud APp works fine on the HP laptop but still does not work on the Dell Laptop.
Any other ideas of what it could be?
Marc_V
May 01, 2018NETGEAR Employee Retired
Hi mvetri
To be honest I am not really sure what's causing the issue since it works on your HP Laptop. I have several workstations as well but none of them gets the same issue as what you have.
It would be better if you can check your Dell laptop's System as it might be missing some components that is causing this.
Regards
- mvetriMay 10, 2018Guide
I've recently update the MS OS on both machines to MS 10 v 1803. Upgrades were successful on both machines, however, I am still having the issue on the Dell.
You mention that I shoul check for missing components. Can you suiggest which component and I can check. I've had a case open with Netgear tech support for 3 weeks and they have come back with no idea of how to resolve the issue.
Any help anyone may have is greatly appreciated.
- Marc_VMay 14, 2018NETGEAR Employee Retired
Hi mvetri
Do you have any Security softwares installed on your Dell PC? You may want to try to disable it then reinstall the app.
Please let me know if this helped.
Regards
- bedlam1May 14, 2018Prodigy
Try updating Java on the Dell, removing previous versions afterwards
