mvetri
Apr 22, 2018Guide
ReadyCloud GUI not working (Desktop App) PRJNAME
I can no longer auto connect with the Ready Cloud App for Windows. I uninstalled the app, then reinstalled, and the interface titles changed and are variable of code and the interface looks weird. ...
Marc_V
May 14, 2018NETGEAR Employee Retired
Hi mvetri
Do you have any Security softwares installed on your Dell PC? You may want to try to disable it then reinstall the app.
Please let me know if this helped.
Regards
bedlam1
May 14, 2018Prodigy
Try updating Java on the Dell, removing previous versions afterwards
