bkou
Jul 07, 2018Aspirant
readycloud ios
Ive written a couple times about this and the issue persits...
I cant access my files through the ios app over my wifi. Its only on my wifi that it doesnt work through the ios app. If i log onto th...
bkou
Jul 08, 2018Aspirant
Thanks Marc,
I was wondering if a new IOS app release will be coming out? Everything but access from the IOS app works so id rather wait before changing somehting on the actual NAS.
it worked when i first installed the IOS app over a year ago then something changed and i have never been able to access since
thanks
Ben
Marc_V
Jul 09, 2018NETGEAR Employee Retired
Hi bkou
Definitely there will be an update but no timeline will be given. Hopefully an update will be rolled out soon.
Please let me know if the Beta FW has resolved the issue, it would be a great benefit to other users having the same experience as yours.
Hope this helps!
Regards
- Retired_MemberJul 13, 2018
Hello bkou
Are you still facing folder access issue on IOS app?is it possible to send share access invitation to my account?I will pm you with my test account,thanks!
