Sandshark
Jul 07, 2023Sensei
ReadyCLOUD is dead -- the onslaught begins
Netgear can't be bothered to even put up a "ReadyNAS has been removed" page where the login used to be. You just get routed to the main Netgear page. The Forum is now going to be flooded by user...
wrightson
Jul 10, 2023Tutor
Is the local app for desktop backups also disabled too?
Fergusmagoo
Jul 10, 2023Star
If you were logged into it then the desktop app still works but once logged out it will not create a new link. If you are just using it locally all you have to do is “Map to Drive” as you would normally.
