10X
Jul 17, 2016Aspirant
ReadyCLOUD is unable to discover ReadyNAS102 after MyNetgear migration
Hi all, I'm here to ask for help after a frustrating and unsuccessful migration to MyNetgear. My ReadyNAS 102, now running OS 6.5.1, is all set up for shares via AFP and SMB, which work well. The...
BrianL2
Jul 18, 2016NETGEAR Employee Retired
Hi 10X,
Can you confirm if your migrated ReadyCLOUD (SSO) login is being used as an e-mail address by your local ReadyNAS users? Also, tell us if you have files stored in your ReadyCLOUD private home shares. If you want to detect your ReadyNAS (locally), I suggest that you use the RAIDar utility.
Kind regards,
BrianL
NETGEAR Community Team
10X
Jul 19, 2016Aspirant
Brian, thanks for chiming in.
I've set up only an admin account, there are no other users apart from one dedicated Cloud user (me). When I'm back on-site, I can check which mail address is associated to admin, but I doubt there is any (can't remember having done that). No home dirs are being used. I'm familiar with RAIDar, which offers no functionality for linking (in order to access the 102 off-site via ReadyCLOUD services) ReadyCLOUD with the 102. If it does, please elaborate.
Kind regards, Pat
- AbraJNAJul 19, 2016Aspirant
I have the same model and since the last update have not been able to access the 102 remotely.
I had huge issues after the last update and still cannot access the R102 with the pc I did the upgrade on.
Pretty fed up and looking at changing to a different suppler.
