10X
Jul 17, 2016Aspirant
ReadyCLOUD is unable to discover ReadyNAS102 after MyNetgear migration
Hi all, I'm here to ask for help after a frustrating and unsuccessful migration to MyNetgear. My ReadyNAS 102, now running OS 6.5.1, is all set up for shares via AFP and SMB, which work well. The...
gpaolo
Jul 21, 2016Luminary
Hi, I have a R314 and I had a similar issue. I am not sure if this was the fundamental step, but one of the things I changed before being able to have my NAS discovered was the email address of one of the users. The ReadyCloud account and the user account had the same email address. Once I changed the user address (and unregistered the NAS from ReadyCloud services, tried the offline method, tried the manual method...) and I relogged in on the Cloud configuration page, the NAS "magically" appeared on the ReadyCloud web page.
I hope it helps!
Regards
AbraJNA
Jul 21, 2016Aspirant
Hi - That worked exactly as described - I am so grateful for your help - countless emails with Netgear support failed to resolve the problem - you are the Master, Thanks
- gpaoloJul 21, 2016Luminary
Good! I am glad it has worked. Let's hope that it is the solution also for everybody else!
