clinford
May 25, 2017Aspirant
ReadyCLOUD login issues after 6.7.3 Firmware update
Upgraded from 6.7.1 to 6.7.3 and rebooted and found ReadyCLOUD was off, so put in username and password and got the Error "Local user with the same name already exists. Change local or ReadyCLOUD use...
BingkeX
May 26, 2017NETGEAR Expert
Hello clinford,
Would you please clear browser cache or use another browser and reboot your nas, then try again to see if you still see this issue?
Best Regards.
- mdgm-ntgrMay 27, 2017NETGEAR Employee Retired
Please also check if you still see the issue on ReadyNAS OS 6.7.4 which is now available!
- clinfordJun 03, 2017Aspirant
As suggested I have upgraded to 6.7.4, rebooted, clear browser cache also tried from another PC, still the same.
- JennCJun 07, 2017NETGEAR Employee Retired
Hello clinford,
Make sure that local users and cloud users do not have the account name that you have entered. Then reboot the NAS 2x, then try again.
