RichardSPC
May 05, 2016Aspirant
Readycloud migration and Firmware update
Hi guys, I have had the same email that others have had regarding migration of Readycloud account to a single Netgear account. I have ceased using Readycloud for access due to inconsistencies...
- May 05, 2016
If you don't use ReadyCLOUD then you wouldn't need to install the firmware update straightaway or upgrade your ReadyCLOUD account to a SSO account.
However running such an old firmware as 6.2.0 you are missing a number of enhancements, bug fixes, security fixes and other improvements.
mdgm-ntgr
May 05, 2016NETGEAR Employee Retired
- RichardSPCMay 06, 2016Aspirant
Thank you mdgm. That is what I thought but wanted to check. I am not overly bothered about the bells and whistles enhancements as I simply use it for storage.
- StephenBMay 06, 2016Guru - Experienced User
There are some enhancements to storage which might be of interest.
-disk quotas for each share
-custom snapshot configurations
Perhaps browse the release notes for 6.4.x and 6.5 beta.
