RichardSPC
May 05, 2016Aspirant
Readycloud migration and Firmware update
Hi guys, I have had the same email that others have had regarding migration of Readycloud account to a single Netgear account. I have ceased using Readycloud for access due to inconsistencies...
- May 05, 2016
If you don't use ReadyCLOUD then you wouldn't need to install the firmware update straightaway or upgrade your ReadyCLOUD account to a SSO account.
However running such an old firmware as 6.2.0 you are missing a number of enhancements, bug fixes, security fixes and other improvements.
uzs4w2
May 09, 2016Aspirant
Hi,
short question. I got the mail to migrate to the new ReadyCloud and to upgrade the Firmare of my NAS to 6.5.0
Any idea how to upgrade if 4.2.2 is the latest availabvle ?????
Thanks for any idea and best,
Alex
May 09, 2016Guru - Experienced User
ReadyCloud is only for OS6 (not OS 4.2).
Netgear doesn't support OS6 on your ultra plus, but it is possible to install it. There are instructions in the forum is you are interested. The process destroys all your data, so you will need a full backup.
