Daktari
Feb 16, 2016Guide
ReadyCLOUD not connecting
I have a readycloud installed on an iMac runing MacOS 10.11.3. New install of ReadyCloud for MacOS v2 FM ver 6.4.2 I suddenly have a problem with connecting. The following situation applies: ...
- Feb 17, 2016
I disabled IPv6 on the ethernet adapter for the RN202, this solved the problem.
Thanks, hope it helps someone else.
scravatt
Feb 17, 2016Apprentice
Same problem here. It used to work fine until after the 6.4.2 OS upgrade, I suspect there is a bug. I can access my NAS from the readycloud website, but like others, the readycloud app on client (windows) and iphone (IOS) doesn't connect ...keeps spinning and trying to connect..this has been on/off for the alst week..starting Sat 2/13/16. Sometimes it connects, sometimes it doesn't. VERY FRUSTRATING.
