Daktari
Feb 16, 2016Guide
ReadyCLOUD not connecting
I have a readycloud installed on an iMac runing MacOS 10.11.3. New install of ReadyCloud for MacOS v2 FM ver 6.4.2 I suddenly have a problem with connecting. The following situation applies: ...
- Feb 17, 2016
I disabled IPv6 on the ethernet adapter for the RN202, this solved the problem.
Thanks, hope it helps someone else.
BrianL2
Feb 16, 2016NETGEAR Employee Retired
Hi Daktari,
Do you have the internet and services online check marks under the Cloud tab? Also, if you will try to sign-in via https://readycloud.netgear.com/ can you check if you can see your ReadyNAS and access your files?
Looking forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
Daktari
Feb 17, 2016Guide
any suggestions?
