Daktari
Feb 16, 2016Guide
ReadyCLOUD not connecting
I have a readycloud installed on an iMac runing MacOS 10.11.3. New install of ReadyCloud for MacOS v2 FM ver 6.4.2 I suddenly have a problem with connecting. The following situation applies: ...
- Feb 17, 2016
I disabled IPv6 on the ethernet adapter for the RN202, this solved the problem.
Thanks, hope it helps someone else.
JennC
Jul 09, 2016NETGEAR Employee Retired
Hello wolfie111,
If you have purchased the RN516 after June 1 2014, I suggest you contact support center as your RN516 comes with lifetime CHAT support.
wolfie111
Jul 09, 2016Guide
Thanks Jenn,
But the unit was a warranty replacement and original Ultra6 was purchased 2011, thus out of support warranty.
Really need some help here.
Thanks in advance,
Rob
