LeapingLemming
Jun 11, 2017Tutor
ReadyCLOUD not connecting
 I have read thread after thread for the past two days trying to work why I cannot connect to Readycloud anymore. Nothing suggested works.     Some info:  1  ReadyNAS 104 with 4 drives on 6.7.4  2  Re...
- Jun 23, 2017
Finally fixed. I think it was related to a deleted user message months ago. Regardless it took Netgear L3 support to fix, something about removing old settings. Thanks for your help anyway
Jun 14, 2017Guru - Experienced User
LeapingLemming wrote:
I do have a deleted user message on 30-March-17.
Have you seen this?
https://community.netgear.com/t5/ReadyCLOUD/Having-ReadyCLOUD-problems-since-3-30-17/td-p/1259697
LeapingLemming
Jun 14, 2017Tutor
Yes and I sent the email as stated, just in case. But that was 2 months before my problems arose. I was going fine up to 30-May.
- StephenBJun 14, 2017Guru - Experienced User
Ok. The bulletin of course explains the 30-March log entry you noted above.
