Howste
Feb 16, 2021Tutor
ReadyCloud not loading in Google Chrome
Just today noticed that the ReadyCloud login just endlessly loops a refresh once I attempt to login to the Ready cloud Web on Chrome browser. I switched to MSFT Edge and it logs in and accesses my da...
- Feb 19, 2021
Thanks for the additonal note as I was wondering if I was the only one!
After some troubleshooting and same fixes you mentioned (Cache, cookies, etc...) I decided to attempt a reinstallation of Chrome Browser.
I synced my Google account, uninstalled Chrome (ensuring I removed all data), and then reinstalled Chrome from the download provided by Google (quick search got me that). The ReadyCloud came right up with no additional issues, I downloaded the desktop app and was back up and running.
The only issue I have found is my users had to go back and do some minor tweaking of Chrome to get back to thier usual tasks, etc...
Hope that helps!
Howste
Feb 19, 2021Tutor
Hope that helps!
dhirsch
Feb 19, 2021Initiate
Many thanks to you too for posting on this forum - when I first looked there was nothing on here which I thought was strange. Even now I am surprised that more people are not reporting this issue.
For anybody still having problems I thought I would add to Howste's post to say that the first time I did the Chrome reinstall the problem did not go away, because I did not remove all data - there was an option on the uninstall to remove browsing data, but that was clearly insufficient.
A Google search suggests that to fully uninstall Chrome in Windows 10 you should delete the Chrome folders in the following locations:
- C:\Users\<YOURUSERNAME>\AppData\Local\Google\
- C:\Program Files (x86)\Google\
In my case I did not have a Chrome folder in either location, but I deleted most of the folders I found (I left Chrome Remote Desktop and Backup and Sync). I then reinstalled Chrome and am pleased to say Chrome browser access to ReadyCLOUD is now working again - I have repeated this on two computers and both now work.
Good luck to anybody else with this issue!
