esung
Jul 31, 2017Follower
ReadyCloud or equivalent for Orbi+ReadyNAS NV+ combo?
Hello. New user here. I'm looking for a way to access my ReadyNAS NV+ (2009 ish model. firmware 4.1.16) via cloud using readyCloud or whatever superseded it. I tried to follow the steps to add N...
Jul 31, 2017Guru - Experienced User
The current ReadyCloud only supports OS-6 ReadyNAS, it doesn't support your NV+.
However, Orbi does include OpenVPN. With OpenVPN you can securely access your full home network from your mobile device or laptop while you are away from home. That includes access to the files on your NV+.
