ranc
Aug 15, 2015Aspirant
ReadyCLOUD PC Client issues & General Beginner Help
Hi there, I've got a couple of issues I can't seem to find resolve myself or find answers on these forums (although a few others appear to have had same issues in past): 1. Have downloaded re...
- Sep 02, 2015
Hi ranc,
Try this on the PC where it gets stuck at initialize or initializing state.
Kind regards,
BrianL
NETGEAR Community
BrianL2
Aug 15, 2015NETGEAR Employee Retired
Hi ranc,
Are these PCs connected on the same network? What are the OS running (the one that works and the other one that doesn't) in both machines? Using the ReadyCLOUD desktop app to backup folders (default PC folders) creates shares on the ReadyNAS once the sync has been created and started. If all (PCs and NAS) are on the same network the best solution to backup specific folders in each PC, is to create individual backup jobs. You may want to check the articles below for more information.
Creating a backup job - http://kb.netgear.com/app/answers/detail/a_id/23420/~/how-do-i-create-a-backup-job-on-my-readynas-os-6-storage-system%3F
Modifying a backup job - http://kb.netgear.com/app/answers/detail/a_id/26443
Windows PC backup - http://kb.netgear.com/app/answers/detail/a_id/24913/~/how-do-i-backup-my-windows-pc-to-a-readynas-os-6-system-using-windows-backup
ReadyCLOUD PC and mobile backup - http://www.netgear.fr/images/pdf/NETGEAR_Reviewer%20Guide_ReadyNAS_6_2_18Nov14_EN.PDF
Hope this helps!
Kind regards,
BrianL
NETGEAR Community
