ranc
Aug 15, 2015Aspirant
ReadyCLOUD PC Client issues & General Beginner Help
Hi there, I've got a couple of issues I can't seem to find resolve myself or find answers on these forums (although a few others appear to have had same issues in past): 1. Have downloaded re...
- Sep 02, 2015
Hi ranc,
Try this on the PC where it gets stuck at initialize or initializing state.
Kind regards,
BrianL
NETGEAR Community
BrianL2
Aug 15, 2015NETGEAR Employee Retired
Hi ranc,
Are these PCs connected on the same network? What are the OS running (the one that works and the other one that doesn't) in both machines? Using the ReadyCLOUD desktop app to backup folders (default PC folders) creates shares on the ReadyNAS once the sync has been created and started. If all (PCs and NAS) are on the same network the best solution to backup specific folders in each PC, is to create individual backup jobs. You may want to check the articles below for more information.
Creating a backup job - http://kb.netgear.com/app/answers/detail/a_id/23420/~/how-do-i-create-a-backup-job-on-my-readynas-os-6-storage-system%3F
Modifying a backup job - http://kb.netgear.com/app/answers/detail/a_id/26443
Windows PC backup - http://kb.netgear.com/app/answers/detail/a_id/24913/~/how-do-i-backup-my-windows-pc-to-a-readynas-os-6-system-using-windows-backup
ReadyCLOUD PC and mobile backup - http://www.netgear.fr/images/pdf/NETGEAR_Reviewer%20Guide_ReadyNAS_6_2_18Nov14_EN.PDF
Hope this helps!
Kind regards,
BrianL
NETGEAR Community
ranc
Aug 31, 2015Aspirant
Hi Brian,
Thanks for getting back to me. I'm still stuck and TBH have thrown this whole thing in the too hard basket because I'm flat out with work and have no time to troubleshoot this. I understand how to get backups workign but that's not what I want - I want to get the sync function moving, that's a huge part of why I got this system - so my various devices can be syncing continuously the data that I want them to be.
The last few weeks I've just been working at home directly off the NAS which is fine. 2 things have changed which have brought me back to try and trouble shoot this again.
1. Had critically important meeting Fri and forgot data was no longer on my local drive and all on my NAS. #(*&$^&*(@. Could access via readycloud web portal (or whatever it's called) but unfortunately we in Australia have 3rd world internet speeds so trying to access docs took over a min a pc .. and that was a for a plain text word doc.
2. on Sunday I noticed the Readycloud PC Client had initialised on Laptop 2 (which it previously didn't) - no idea what changed .. I thought maybe there had been an update that had come through that had fixed it. I've just turned that machine on again and unfortunately it's again not initialising (slaps forehead).
2. So going back to your original questions:
a. yes both on home network.
b. O/S: The one that readycloud app works on Laptop 1 (Work) = Windows 7 enterprise. The one it didn't initialise on (or did briefly) / Laptop 2 = Windows 7Pro.
Maybe there's something from the event log or somewhere that will give more detail as to why the 2nd laptop won't initalise (but did on weekend). It's bizarre. Laptop 2 hasn't left the house. Laptop 1 was the one that went out of town with me for above meeting. It did connect in to another network several times while I was out of town (a family member's home one).
This is all beyond me - clearly - but it's causing me a massive amount of waste time and aggravation and I need to get this fixed.
Is there a helpline I can speak to?
Thanks
Ros
