ranc
Aug 15, 2015Aspirant
ReadyCLOUD PC Client issues & General Beginner Help
Hi there, I've got a couple of issues I can't seem to find resolve myself or find answers on these forums (although a few others appear to have had same issues in past): 1. Have downloaded re...
- Sep 02, 2015
Hi ranc,
Try this on the PC where it gets stuck at initialize or initializing state.
Kind regards,
BrianL
NETGEAR Community
ranc
Sep 02, 2015Aspirant
Sure Brian, happy to try anything.
Which of the problems do you hope this will fix - initialisation on laptop or the sync/backup issue as per the dwad thread?
Thanks,
Ros
BrianL2
Sep 02, 2015NETGEAR Employee Retired
Hi ranc,
Kind regards,
BrianL
NETGEAR Community
- rancSep 02, 2015Aspirant
Hi Brian,
Thank you - this seems to have fixed the other laptop. :womanhappy::womanvery-happy: Let's hope the fix holds as it was working for a while.
Appreciate your help on this and I will post another thread re the readycloud client.
Thank you.
Ros
- BrianL2Sep 02, 2015NETGEAR Employee Retired
Hi ranc,
That's good news! Just keep an eye on it and hopefully the problem won't reoccur.
Kind regards,
BrianL
NETGEAR Community
