sxchapma
Feb 06, 2015Aspirant
ReadyCloud share sync to PC never ends
I have a ReadyNAS 104 with the most recent firmware running at home. I had been using the old PC software but got rid of it and now am trying out the new ReadyCloud windows software. While the lo...
nikoniko
Aug 08, 2015Tutor
Hi
I am having the same issue with RadyNAS 102, with the latest fw 6.2.5
Is there any solution to this problem?
Also I have noticed that the ReadyDrop process keeps my disc busy constantly at a level of at least 50%.
With this rate I would propably have to replace the disc within the year
brg
Nikolas
nikoniko
Dec 28, 2015Tutor
The issue is stilll not resolved with the latest release 6.4.1 and the latest ReadyCloud application on Windows 10 but I found a solution to an application by Microsoft called SyncToy.
It does exasctly what I want. You set up a local folder and remote folder on ReadyNAS and it will sync the folders.
For the android devices I found FolderSync which works similarly settign up a local folder on the internal memory or on the external sdcard and then you can select a SMB server to sync.
Hope it helps you sync your files.
Nikolas
