sxchapma
Feb 06, 2015Aspirant
ReadyCloud share sync to PC never ends
I have a ReadyNAS 104 with the most recent firmware running at home. I had been using the old PC software but got rid of it and now am trying out the new ReadyCloud windows software. While the lo...
nikoniko
Aug 08, 2015Tutor
Hi
I am having the same issue with RadyNAS 102, with the latest fw 6.2.5
Is there any solution to this problem?
Also I have noticed that the ReadyDrop process keeps my disc busy constantly at a level of at least 50%.
With this rate I would propably have to replace the disc within the year
brg
Nikolas
- nikonikoDec 28, 2015Tutor
The issue is stilll not resolved with the latest release 6.4.1 and the latest ReadyCloud application on Windows 10 but I found a solution to an application by Microsoft called SyncToy.
It does exasctly what I want. You set up a local folder and remote folder on ReadyNAS and it will sync the folders.
For the android devices I found FolderSync which works similarly settign up a local folder on the internal memory or on the external sdcard and then you can select a SMB server to sync.
Hope it helps you sync your files.
Nikolas
