joopblog
Jul 08, 2020Follower
ReadyCloud Sign-In Not Recognized - trying to connect ReadyNAS 212
Unable to log into https://readycloud.netgear.com using my previously working email and password - after I logged in to attempt to add my wife's email for ReadyNAS cloud access. I cancelled partiall...
- Jul 12, 2020
Hi joopblog,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as a solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
JohnCM_S
Jul 08, 2020NETGEAR Employee Retired
Hi joopblog,
Welcome to the Community!
Can you try logging in your account to the myNETGEAR portal then change your password there? After changing your password, please check if you will be able to login to the ReadyCLOUD web portal using the new password.
JohnCM_S
Jul 12, 2020NETGEAR Employee Retired
Hi joopblog,
