icyvran's avatar
icyvran
Tutor
May 24, 2015
ReadyCLOUD SSL security
Hi,
As you can see at https://dev.ssllabs.com/ssltest/analyze.html?d=readycloud.netgear.com there are some improvements to be made to the SSL connection to readycloud.netgear.com
As of today, the SSL connection gets an F rating.
Thanks,
icyvRan
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Thanks for reporting this. I have passed on your feedback to our engineering team.
  • Hello again,
    Please let the engineering team know that the issues are also present in the SSL configuration of remote.readynas.com and replicate.readynas.com
    https://www.ssllabs.com/ssltest/analyze.html?d=remote.readynas.com
    https://www.ssllabs.com/ssltest/analyze.html?d=replicate.readynas.com
    Aldo, they should know that https://www.readynas.com has a C rating
    https://www.ssllabs.com/ssltest/analyze.html?d=readynas.com
    Thanks,
  • Hello again,
    For a guide on server side TLS configuration, take a look at: https://wiki.mozilla.org/Security/Server_Side_TLS
    Hope it helps
    mdgm-ntgr
    We have a fix coming (no ETA) which if that site remains the same will improve the grade to a "C". However some things we cannot change in order to maintain backwards compatibility for users running old firmware.
ProSupport for Business
