icyvran
May 24, 2015Tutor
ReadyCLOUD SSL security
Hi,
As you can see at https://dev.ssllabs.com/ssltest/analyze.html?d=readycloud.netgear.com there are some improvements to be made to the SSL connection to readycloud.netgear.com
As of today, the SSL connection gets an F rating.
Thanks,
icyvRan
Thanks,
icyvRan
- mdgm-ntgrNETGEAR Employee RetiredWe have a fix coming (no ETA) which if that site remains the same will improve the grade to a "C". However some things we cannot change in order to maintain backwards compatibility for users running old firmware.
- icyvranTutorHello again,
For a guide on server side TLS configuration, take a look at: https://wiki.mozilla.org/Security/Server_Side_TLS
Hope it helps - StephenBGuru - Experienced UserIf it "helps" https://www.synology.com gets an "A".
https://www.ssllabs.com/ssltest/analyze ... com&latest
But www.usa.gov also gets a "C"
https://www.ssllabs.com/ssltest/analyze ... ww.usa.gov - icyvranTutorHello again,
Please let the engineering team know that the issues are also present in the SSL configuration of remote.readynas.com and replicate.readynas.com
https://www.ssllabs.com/ssltest/analyze.html?d=remote.readynas.com
https://www.ssllabs.com/ssltest/analyze.html?d=replicate.readynas.com
Aldo, they should know that https://www.readynas.com has a C rating
https://www.ssllabs.com/ssltest/analyze.html?d=readynas.com
Thanks, - mdgm-ntgrNETGEAR Employee RetiredThanks for reporting this. I have passed on your feedback to our engineering team.
