GPSIS_HQ
Jul 02, 2016Guide
ReadyCloud States ReadyNAS 204 Offline
Hello all, Yesterday I started getting a notification from the ReadyCloud PC client that my RN204 was Offline. This started after I went away for the 4th weekend and tried to connect from my lapt...
- Jul 05, 2016
Brian,
Thanks for the speedy reply.
The problem, as it turns out was that the RN204 was indeed powered off due to an over heating issue, which was not due to the NAS but the ambient heat of my appartment.
While away for a long weekend I turned off the thermostat to save cost, thus the apartment heated up pretty good in this Southern humidity.
Now that begs to ask why could I get to the RN204 with the mobile app, but not the web browser...anyway it's a non issue now and it is back online.
Thanks for the assist!
BrianL2
Jul 03, 2016NETGEAR Employee Retired
Hi GPSIS_HQ,
Yes, you should. I suppose that you're away for the weekend and using another network from where you at. Let me know if you have tried it another PC with the same up to date version of the desktop client.
Kind regards,
BrianL
NETGEAR Community Team
GPSIS_HQ
Jul 05, 2016Guide
Brian,
