klausn
Mar 31, 2018Tutor
ReadyCloud v2.0.1(today updated) but seems it doesn't work
Hi anyone, Do you update to the latest version ReadyCloud v2.0.1 (iPhone 7+), but seems it doesn't work. Just start the app and nothing happens, does anyone have the same issue? Can't logout or...
- Retired_MemberApr 26, 2018
Hello all
I uploaded patch files(fix 409 conflict issue) to ReadyCLOUD,please download them at
for X86 device
https://readycloud.netgear.com/client/dllink.html#t=002jm6o5pm6/readynasos_6.9.3%2B3_amd64.deb
for ARM device
https://readycloud.netgear.com/client/dllink.html#t=07g704laopx/readynasos_6.9.3%2B3_armel.deb
klausn
Mar 31, 2018Tutor
Suggestion for all,
Reboot your iPhone and wait a while! (10 min.)
- klausnMar 31, 2018Tutor
I can logout, yeah....!
Login again and try to upload my pictures >9000 (pictues), but no luck today!
Anyway the latest update doesn't solve the earlier issue (reported last year 2017): "Error Request faild: 409 - conflict (in ReadyCloud)".
Error Request faild: 409 - conflict (in ReadyCloud) - this problem is still there!
- Kmalin15Apr 02, 2018AspirantI updated my app as well and had the same problem of it not working. I turned off my phone for a few minutes, turned it back on, and then it started working. My biggest problem is that it reset my media backup so it wanted to copy 8,000 plus pictures to the ReadyNAS again. Then in conjunction with the server 409 error, I gave up. I started backing up photos via a usb flash drive with the lightning plug for iPhone. Then take that Backup, plug it into the computer and drag and drop onto the ReadyNAS. I can access all my photos and now I have an additional backup stored on a flash drive as well.
- Retired_MemberApr 03, 2018
Hello Kmalin15
Did you backup photos in your home network(LAN mode)?I don't see such error when backing up 4000+ photos to ReadyNAS.
can you change destination folder to see if it can fix the issue?
