klausn
Mar 31, 2018Tutor
ReadyCloud v2.0.1(today updated) but seems it doesn't work
Hi anyone, Do you update to the latest version ReadyCloud v2.0.1 (iPhone 7+), but seems it doesn't work. Just start the app and nothing happens, does anyone have the same issue? Can't logout or...
- Retired_MemberApr 27, 2018
Hello all
I uploaded patch files(fix 409 conflict issue) to ReadyCLOUD,please download them at
for X86 device
https://readycloud.netgear.com/client/dllink.html#t=002jm6o5pm6/readynasos_6.9.3%2B3_amd64.deb
for ARM device
https://readycloud.netgear.com/client/dllink.html#t=07g704laopx/readynasos_6.9.3%2B3_armel.deb
walshlink
Apr 15, 2018Luminary
It appears if my iOS device is connected to the LAN through WiFi, I get the error. Once I shut down WiFi and go through my cellular data connection, the iOS ReadyCloud app connect to my NAS. When I turned on WiFi again, shutdown my cellular data connection, the error comes back.
NETGEAR, the problem clearly lies with the iOS ReadyCLOUD app not being able to use the local LAN when there is one available (unless that is by design and can only get to the NAS through the Internet).
walshlink
Tried to upload photos using ReadyCLOUD app and it immediately crashes. App is completely usuable at this point.
- greispeApr 15, 2018Tutor
I confirmed the exact same behavior as Walshlink. The app is definitely flakey. Works on cell connection, doesn't work Local LAN.
- walshlinkApr 15, 2018LuminaryUsing cellular data (and disabling WiFi) seems to work just fine.
- klausnApr 16, 2018Tutor
Hi all,
Do you have the same problem as me with ReadyCloud (v2.0.1) on a iPhone (iOS11.3)?
I have a small update:
Netgear provided me today an higher version (v2.0.2) for testing it. It seems that this version also isn't working!
(Even I created a new directory! It's not working)
Netgear is on the moment busy to find the root cause.
When they have found it they will solve it with a new relase!
So keep in touche, I will update this Topic in here when it is solved!
Klaus
