jabshettys
Sep 16, 2016Aspirant
ReadyCLOUD won't discover my NAS RN102 6.5.1
Hi, From 2 days i am trying to get this readycloud work. Let me explain where i am stuck now. NAS: RN102 Frimware:6.5.1 Static IP: 192.168.1.100 DNS:8.8.4.4/4.4.2.2 1. I am able to turn...
- Sep 21, 2016
Your logs showed that a configuration file was corrupt. Overwriting it with the default one resolved the problem.
JennC
Sep 17, 2016NETGEAR Employee Retired
Hello Jabshettys,
Do you mean to say ReadyCloud never worked before on your ReadyNAS? if so, then there is no ReadyCloud users home shares yet stored to the volume. If so, turn it off then leave ReadyCloud from the admin page > Cloud > ReadyCloud. Please log out from ReadyCloud portal too.
Make sure that ReadyCloud (MyNetgear) account name which is in an email address format is not listed under Accounts > Users.
Then go back to admin page and turn ReadyCloud back on, enter the same ReadyCloud (MyNetgear) account then log back in to the ReadyCloud portal. Click Settings button, make sure "Use Proxy Settings"is unchecked under Proxy Settings and "Encryption" should not be marked under Security.
Welcome to the community!
jabshettys
Sep 17, 2016Aspirant
Thanks JennC for the reply.
Yes, i have never used readycloud before. I can see the same email address under accounts tab>Cloud user. and its not under Accounts>users.
I am not able to remove the cloud user.
Under Shares i can see this email address has permissions to access the shares.
Security and Encryption are not marked.
Thanks,
Sachin
- jabshettysSep 20, 2016Aspirant
i am still unable to get it work.
Please can someone help me on this.
- mdgm-ntgrSep 20, 2016NETGEAR Employee Retired
Can you update to ReadyNAS OS 6.5.2 which is now available and send in your logs (see the Sending Logs link in my sig)?
Hi mdgm,
i have updated the firmware and sent you the log. Please check and let me know further steps.
Thanks,
Sachin
- JennCSep 20, 2016NETGEAR Employee Retired
Hello Jabshettys,
I see. Did you already try leaving the ReadyCloud from the admin page?
Hi,
Yes i tried to leave the cloud and join again and under cloud user it says "This device is joined to Readycloud"
