jabshettys
Sep 16, 2016Aspirant
ReadyCLOUD won't discover my NAS RN102 6.5.1
Hi, From 2 days i am trying to get this readycloud work. Let me explain where i am stuck now. NAS: RN102 Frimware:6.5.1 Static IP: 192.168.1.100 DNS:8.8.4.4/4.4.2.2 1. I am able to turn...
- Sep 21, 2016
Your logs showed that a configuration file was corrupt. Overwriting it with the default one resolved the problem.
jabshettys
Sep 17, 2016Aspirant
Thanks JennC for the reply.
Yes, i have never used readycloud before. I can see the same email address under accounts tab>Cloud user. and its not under Accounts>users.
I am not able to remove the cloud user.
Under Shares i can see this email address has permissions to access the shares.
Security and Encryption are not marked.
Thanks,
Sachin
jabshettys
Sep 20, 2016Aspirant
i am still unable to get it work.
Please can someone help me on this.
- mdgm-ntgrSep 20, 2016NETGEAR Employee Retired
Can you update to ReadyNAS OS 6.5.2 which is now available and send in your logs (see the Sending Logs link in my sig)?
- jabshettysSep 20, 2016Aspirant
Hi mdgm,
i have updated the firmware and sent you the log. Please check and let me know further steps.
Thanks,
Sachin
- JennCSep 20, 2016NETGEAR Employee Retired
Hello Jabshettys,
Can you PM me the account details of your ReadyCloud? I will just try and see if I get the same results.
Hello Jabshettys,
I see. Did you already try leaving the ReadyCloud from the admin page?
Hi,
Yes i tried to leave the cloud and join again and under cloud user it says "This device is joined to Readycloud"
