restockton
Feb 11, 2016Follower
ReadyNas 102 and deleted ReadyCloud account
I have two readynas 102 units. They were set up and working perfectly in two different locations. I had them backing up to each other and life was good. Then one day one of the two units decided n...
JennC
Feb 12, 2016NETGEAR Employee Retired
Hello restockton,
Welcome to the community!
I believe you are referring to ReadyNAS Replicate since you mentioned that the two NAS units are backing up to each other.
ReadyCloud and ReadyNAS Replicate accounts are just the same, anyway. Yes you could use the old ReadyCloud account to any ReadyNAS units. Just go to admin page and click Cloud, you should see ReadyCloud, ReadyNAS Remote and ReadyNAS Replicate, just turn them all of then click Settings of ReadyCloud, click Leave then enter turn it back on, you should get a pop up window asking for ReadyCloud login. If it does not ask you for ReadyCloud login, it will still use the current one, this sometimes happens so just try doing it again or use another web browser.
