stardork's avatar
stardork
ReadyNAS 104 - can't reassemble volume
My girlfriend's ReadyNAS had a disk go bad so it was showing as a degraded volume. She pulled the wrong disk out (disk 4 was bad but she accidentally pulled 3). Immediately put the disk back in when ...
  • StephenB's avatar
    Jan 16, 2024
    You need to use the --force (or perhaps --really-force) option to assemble the array.
    The instructions (starting from when you log into tech support mode) are
    # rnutil chroot
    # mdadm --assemble --really-force /dev/md127 /dev/sd[abcd]3
    # btrfs device scan
    # btrfs fi show
    # mount /dev/md127 /data
    # ls /data
    There could be some data loss - the fact that the array isn't assembling suggests there were cached writes that never made it to the drive she pulled.
ProSupport for Business
