MWilkinson
Jun 05, 2022Aspirant
ReadyNAS 104 - Volume: Volume data health changed from Degraded to Dead
I have a replacement disk on it's way because the disk in bay 4 has shown an increasing ATA error count. However, whilst the disk is on it's way Disk 2 went offline and, after a reboot of the ReadyNAS has come back online.
The following error is in the logs:
04 Jun 2022 07:36:39 PM Volume: Volume data health changed from Degraded to Dead.
04 Jun 2022 01:00:10 AM Volume: Volume data is Degraded.
When I look at the shares on the NAS, it says
"No Volume Exits, Netgear recommends that you create a volume before configuring other settings".
Does this mean all the data, including 15 years of family photos and videos are gone forever? That thought makes me feel physically sick.
#any help in saving, recovering the data is appreciated!!
- SandsharkSensei
There are possibilities, but you have to give more detailed information. From the very basic information you provided, it sounds unlikely you'll be able to re-assemble the volume intact, so you'll be in a data recovery mode and many files may be corrupt. And it's not going to be cheap. The first step you'll want to do is try to clone each of the failed drives. That's the best step to keep additional errors from making things worse. Then you can use the services of Netgear or data recovery software to see what can be resurrected. For that, you're going to need a place to hold the recovered data.
- MWilkinsonAspirant
Hi Sandshark,
Thanks for the reply and, yes, I didn't put loads of detailed information mainly because I'm not really sure what information is needed.
From loads of Googling and (very carefully) looking around i came across a log file called '1' in the NAS root folder which contains 1 entry:
root@GDN-NAS:/# cat 1
ERROR: not a btrfs filesystem: /dataIf I look in the Volumes page of the NAS it shows both a data volume as well as a data-0 volume so I (maybe naively) making the assumption that, because the NAS saw the original data volume as non-btrfs it tried to use the disks to create another one which it dynamically named data-0?
Would it be fair to assume that, because no data has actually been written to the new data-0 volume that the original data is intact, and therefore recoverable?
I do have access to a standalone external hard drive caddy and I natively use Linux Mint which seems positive (if there is anything positive about my situation) because Linux could be useful in trying to recover any data?
Is there any detail I can provide to help troubleshoot? I have ssh root access to the NAS.
Thanks
FWIW, the main do-it-yourself path is to attempt to clone either disk 2 or disk 4 (or both) with a tool that does sector-by-sector cloning. If this is successful, then you could attempt to boot the NAS in read-only mode with disks 1, 3, and the cloned disk(s) in place.
You can alternatively attempt to use a RAID recovery tool that supports BTRFS like ReclaiMe, with the intact and cloned disks.
One takeaway here is that RAID isn't enough to keep data safe. Hopefully you will get it back. Then I recommend putting a backup plan in place for your NAS.
