MWilkinson
Jun 05, 2022Aspirant
ReadyNAS 104 - Volume: Volume data health changed from Degraded to Dead
I have a replacement disk on it's way because the disk in bay 4 has shown an increasing ATA error count. However, whilst the disk is on it's way Disk 2 went offline and, after a reboot of the ReadyN...
Sandshark
Jun 05, 2022Sensei
There are possibilities, but you have to give more detailed information. From the very basic information you provided, it sounds unlikely you'll be able to re-assemble the volume intact, so you'll be in a data recovery mode and many files may be corrupt. And it's not going to be cheap. The first step you'll want to do is try to clone each of the failed drives. That's the best step to keep additional errors from making things worse. Then you can use the services of Netgear or data recovery software to see what can be resurrected. For that, you're going to need a place to hold the recovered data.
MWilkinson
Hi Sandshark,
Thanks for the reply and, yes, I didn't put loads of detailed information mainly because I'm not really sure what information is needed.
From loads of Googling and (very carefully) looking around i came across a log file called '1' in the NAS root folder which contains 1 entry:
root@GDN-NAS:/# cat 1
ERROR: not a btrfs filesystem: /data
If I look in the Volumes page of the NAS it shows both a data volume as well as a data-0 volume so I (maybe naively) making the assumption that, because the NAS saw the original data volume as non-btrfs it tried to use the disks to create another one which it dynamically named data-0?
Would it be fair to assume that, because no data has actually been written to the new data-0 volume that the original data is intact, and therefore recoverable?
I do have access to a standalone external hard drive caddy and I natively use Linux Mint which seems positive (if there is anything positive about my situation) because Linux could be useful in trying to recover any data?
Is there any detail I can provide to help troubleshoot? I have ssh root access to the NAS.
Thanks
- StephenBJun 05, 2022Guru - Experienced User
FWIW, the main do-it-yourself path is to attempt to clone either disk 2 or disk 4 (or both) with a tool that does sector-by-sector cloning. If this is successful, then you could attempt to boot the NAS in read-only mode with disks 1, 3, and the cloned disk(s) in place.
You can alternatively attempt to use a RAID recovery tool that supports BTRFS like ReclaiMe, with the intact and cloned disks.
One takeaway here is that RAID isn't enough to keep data safe. Hopefully you will get it back. Then I recommend putting a backup plan in place for your NAS.
- MWilkinsonJun 05, 2022Aspirant
Again, thanks StephenB
Initially I was gutted, but am actually starting to gain a little confidence that maybe there's a slim chance to recover the data.
I've powered off the NAS and powered the disk from bay 1 in a USB attached external drive caddy. Using a Linux PC, and without editing anything instead only looking at directory structures and running cat on various files I can see
[1] /var/backups/shares
contains a bunch of tar files each of which contains the /data/ share folder structure
[2] /var/backups/md
contains a bunch of tar.xz files each of which contains the disk maps and (what I think is) information on the individual disk layouts
What I can't understand is (and is probably where I need help) when I look in the /data/ directory it's completely empty but, when I look at the Admin Web Page there's 2 volumes.
data-0 shows as green, with a red dot saying Inactive or Dead. This volume says 5.44TB data, with 0 Free Space.
data shows as blue, with a red dot which when hovered over is completely blank. This volume says data 0 and Free Space 0
So, how do I tell which is which and where actually the data is supposed to be? I'm reluctant to try to even think about attempting recovery until I least know where things were/are supposed to be.
I can also see from the ssh console:
cat /etc/fstab shows: LABEL=0e34f9fc:data /data btrfs defaults,nodatasum 0 0
Whereas there is a text file '1' in the root which shows:
The /data you are seeing is a mount point - it's empty because the NAS was unable to mount the volume. The data-0 you are seeing on the volume tab is an artifact of the volume not being mountable. The NAS is just calling the unmountable volume data-0.
The NAS uses mdadm to create the RAID array(s) that are then assembled and mounted as /data by BTRFS.
If the disks in your volume are all the same size and your volume was never vertically expanded (smaller disks upgraded to larger ones), then you only have one RAID array - md127. Otherwise, you would have additional volumes (counting down from, so the next one would be md126).
BTRFS then would mount these arrays onto /data.
In your specific case, two disks are no longer in the array. So mdadm can no longer create md127 from the physical disks that remain. If you can successfully clone disk 2 or disk 4, then mdadm ought to be be able to create md127 (though it would be degraded w/o all 4 disks). That might require some override command options if the array is somewhat out of sync.
Then btrfs could mount the file system if there isn't too much corruption due to sectors that couldn't be copied during the cloning operation.
