Calvin386
May 28, 2020Aspirant
ReadyNAS 212 just doens't work (Please tell me I'm wrong)
I have had the ReadyNAS 212 for over a year. I use it as a RAID (2 4tb HDs) backed up to an 8tb HD. There are only personal documents, pictures and video. The intention was to have everything in one ...
May 28, 2020Guru - Experienced User
Is this recent? There has been an issue with ReadyCloud over the past day or so.
You could use openVPN in the R9000 instead of ReadyCloud.
- Calvin386May 29, 2020Aspirant
Thanks for the reply
I wouldn't say recent. It has never really been flawless but it has been manageable. Using the app over cellular has always been somewhat hit or miss. I can get some pictures in a folder but not all despite swiping down the folder to refresh it. Not all the thumbnails will populate in the app and even when they do, I sometimes get the triangle with an exclamation point icon. This has got progressively worse and now virtually nothing will open
Would creating a VPN on my R9000 allow me to use Windows file explorer on my laptop from anywhere? Is there an IOS app that will access the VPN? I currently have my router setup to smart connect with a EXT network for my patio which is in a dark spot. Would a VPN interfere with my router setup?
I'm sure there is plenty of information about VPN in the community which I am willing to read through. I am concerned with unintended concequenses because the rest of my home setup is trouble free
- StephenBMay 30, 2020Guru - Experienced User
Yes and yes. https://kb.netgear.com/29826/How-do-I-use-VPN-on-my-Nighthawk-router-with-my-iOS-device
No (other than possibly requiring you to change some port forwarding if you do that). Certainly it won't interfere with WiFi extenders.
- Calvin386May 31, 2020Aspirant
Thanks... I'll give it a try
