DJ402
Mar 01, 2025Initiate
Readynas 314 drives showing red on admin page and volumes gone
My Readynas 314 became unresponsive after a failed drive replacement attempt. The drive I had on standby didn't work, so I decided to upgrade and transfer the data to a new NAS system. While waitin...
Mar 01, 2025Guru - Experienced User
DJ402 wrote:
My Readynas 314 became unresponsive after a failed drive replacement attempt. The drive I had on standby didn't work, so I decided to upgrade and transfer the data to a new NAS system. While waiting for the new equipment, the volumes disappeared from the admin page. I can boot the system and log into the admin page. I sure hope there is a way to recover this data. Running firmware 6.10.10.
Download the full zip file from the logs page - there will be more info there on what exactly happened.
If you want me to take a look, then put the zip into cloud storage (dropbox, etc), and send me a PM (private message) with a link. Make sure that the permissions are set so anyone with the link can down load.
You send a PM using the envelope icon in the upper right of the forum page.
- DJ402Mar 11, 2025Initiate
So I downloaded USF Explorer ran the trail, it showed recovered data, so I bought the program ($140). I recovered all my files, worked great! Highly recommend.
