jokeruk
Apr 01, 2024Aspirant
ReadyNas keeps 'losing' password
Hi folks, one of my ReadyNas Ultra 6 devices keeps losing its password - admin and others. Losing might not be the right word but symptoms are can no log in to the web interface using admin or any a...
Apr 01, 2024Guru - Experienced User
jokeruk wrote:
Just a thought as I type this question - could this be a battery issue?
No.
jokeruk wrote:
I can still telnet in to root using the admin password in all cases.
Do you mean ssh? Telnet connections are refused unless the NAS is in tech support mode - and that uses a different password.
If you can use ssh, then see if it also works using admin as the user name.
jokeruk wrote:
I've even (as a test) tried leaving it on the default password and after a random period of time (1 week/1 month..) log in access to the UI will be lost.
The symptoms sound more like a PC issue than the NAS.
Have you tried
- connecting both using the NAS hostname and its IP address?
- a different browser?
- using incognito mode?
- a different PC?
- rebooting the NAS from the front panel?
jokeruk
Ah yes sorry, SSH,
using admin and admin password does not work via gui but ‘root’ ad admin password works via SSH
- StephenBApr 01, 2024Guru - Experienced User
jokeruk wrote:
Ah yes sorry, SSH,
Ok.
Have you tried the other tests I suggested?
- jokerukApr 01, 2024Aspirant
Tried both direct ip and nas name
just as an fyi the other NAS is fully accessible from all devices
ok sorry by incognito do you mean private browser?
Rebooting from the fp makes no difference - although i have noticed just recently that shutdown from the fb can take ages
