jokeruk
Apr 01, 2024Aspirant
ReadyNas keeps 'losing' password
Hi folks, one of my ReadyNas Ultra 6 devices keeps losing its password - admin and others. Losing might not be the right word but symptoms are can no log in to the web interface using admin or any a...
jokeruk
Apr 02, 2024Aspirant
OK - Thanks again Stephen.
I've moved my plexdata from var to the /data drive
I created a custom override file for plex pointing to the new location (google is a great tool)
restarted everything and plex seems to work
I ran the du size check and the /var folder has dropped to 91M
Rebooted the NAS
It's started ok and the shares still seem good
Plex seems to have vanished from the installed apps list - but is running (which obviously adds credence to your observation on an incorrect installation (although it was there before)
Plex is also missing from the list of available apps đ
Also many of the GUI menus seem to have strange/different names
I'm still on 6.10.8 - is this an issue?
Question - can I /should I extend the system partition size ?
I will restart and carry out an OS reinstall
Apr 02, 2024Guru - Experienced User
Plex menus? Or are you talking about the NAS web ui?
No. You could update to 6.10.9, but you'd need to install it manually from system->settings->update
Avoid 6.10.10, as it will remove the ability to install apps. You can get rid of the update check on system->settings->update if you haven't done that already.
