joelb
Oct 07, 2017Aspirant
Readynas replication failure
Hello, I have a replication job that had been running succesfully for years that is now failing. This job has over 320 Gb of data already replicated and I'm hoping I can keep all the already repl...
- Oct 11, 2017
Hello joelb,
It does appear you are for some reason getting replicate error -501 where in it was working fine before. It does appear that you would like to preserve your old backup that was previously running and encountered the error. Please check this thread here that appear to be encountering the same problem.
Marty_M
NETGEAR Community Team
Marty_M
Oct 16, 2017NETGEAR Employee Retired
Hello joelb,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
joelb
Oct 16, 2017Aspirant
Hello Marty,
Sorry for being so slow to respond, I just found some time to try the solution.
The solution worked perfectly. As an experiment I first tried to edit the replication job and that did not work. I then deleted the job and recreated it with the same name and directories and that worked perfectly. The replication is now working and all the previously replicated files did not need to be replicated again.
Many thanks for your help,
Joel
