straylight_77
May 29, 2018Aspirant
ReadyNAS RN104 permissions issue
Hi
I am having a lot of trouble with permissions on a ReadyNAS RN104.
It has been configured for local accounts (NOT AD) and is integrated with ReadyCloud for remote access to documents.
The is...
- May 30, 2018
Welcome to the Community!
Is this happening to one user account only? You may want to try and reset the permissions on your Shared folders first.
Restore default file and share folder access
Also if your NAS firmware is not up-to-date I would advise doing so, latest firmware is OS 6.9.3
Warnings:
- Devices updated with 6.9.3 firmware should not be downgraded to firmware versions before 6.9.0.
- ReadyNAS 102, 104, and 2120 must not be updated directly to 6.9.x from 6.3.x or older firmware. They must first be updated to either 6.2.5 or 6.3.5 then to 6.5.2 and then onto 6.9.x.
- ReadyNAS 202, 204, 212 and 212 must not be updated directly to 6.9.x from 6.3.x. They must first be updated to 6.3.5 then 6.5.2 and then onto 6.9.x.
Regards
Marc_V
May 30, 2018NETGEAR Employee Retired
Warnings:
Regards
