mrwizard93
Apr 14, 2015Aspirant
Remote Acces to my Pioneer Pro running 4.2.27 Firmware
What can I do to connect to my ReadyNAS Pioneer Pro running 4.2.27 firmware? I tried using the newer ReadyCloud but that does not work at all (I assume a firmware incompatibility). I saw what l...
RX
Apr 14, 2015Luminary
ReadyCloud is not supported on your NAS running running 4.2.27 firmware unless you install OS 6 firmware on it.
About ReadyNAS Remote, are you using the latest client software? if not, you can download the latest versions of ReadyNAS Remote Desktop software before the ReadyCloud Client came out on these links below:
Windows: http://www.readynas.com/contributed/mdg ... 6.5.23.exe
Mac: http://www.readynas.com/contributed/mdg ... 1.2.15.pkg
You may also try to access the shares remotely via HTTP: http://kb.netgear.com/app/answers/detai ... /related/1
