mrwizard93
Apr 14, 2015Aspirant
Remote Acces to my Pioneer Pro running 4.2.27 Firmware
What can I do to connect to my ReadyNAS Pioneer Pro running 4.2.27 firmware? I tried using the newer ReadyCloud but that does not work at all (I assume a firmware incompatibility). I saw what l...
Apr 15, 2015Guru - Experienced User
There's also lots of threads on the topic posted here.
Ixa wrote: @mrwizard93:
Check this link below about accessing the shares via FTP or FTPS: http://kb.netgear.com/app/answers/detai ... /related/1
The reason to use ftps is that the connection to the NAS is encrypted (similar to using https instead of http). As the article points out, you need to use "explicit" mode. (FileZilla calls it "explicit FTP over TLS"). Implicit mode will fail to connect.
Some apps don't support ftps, so requiring it on the NAS side might not work for you.
