filipinasdelta
Aug 31, 2017Aspirant
Remote Access other than ReadyCloud
Hi all, I'm starting this discussing to hopefully get some help towards remote access. We've got around 5 laptops that we'd like to access the Nas externaly, we used to use 'ReadyNas Remote' which ...
Sandshark
Sep 02, 2017Sensei
I use ZeroTier. Unfortunately, the current app for ReadyNAS is very out of date and the developer disappeared from the scene just a short time after releasing it. It does still work as of OS 6.8.0, or you can install a newer version via standard Linux commands in SSH.
It's operation is much more like ReadyNAS Remote was than ReadyCloud. You activate the connections and then the NAS and other devices running ZeroTier just work like they were on a secondary local network. It even allows NAS-to-NAS remote access for things like offsite backup.
filipinasdelta
Sep 13, 2017Aspirant
Do you know where I can get ZeroTier from?
I went to their website but they haven't got it available for ReadyNas.
Cheers,
- StephenBSep 13, 2017Guru - Experienced User
There's a version here: https://github.com/NAStools/zerotierone/releases/tag/readynas%2F1.1.14-nt3
It's not the latest, but it does work.
