McRob2
Jan 29, 2017Aspirant
Remote User Invite email link invalid
Running firmware 6.6.1 on ReadyNAS 516 I set up readycloud desktop application on local windows and mac computers and all is working fine. I created a new share on the NAS I added a cloud user ema...
- Feb 07, 2017
Hello McRob2,
I see.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
vandermerwe
Jan 29, 2017Master
Everything should be possible using the readycloud portal so no specific desktop app should be needed.
It should not make any difference whether the user sets up the MyNetgear account first.
It sounds like you are doing all the right things.
The readycloud system should really be easier for users than it is. I am also experiencing problems with it that I can't solve.
- JennCJan 30, 2017NETGEAR Employee Retired
Hello vandermerwe,
We are currently having outage with ReadyCloud desktop client. This has been reported to the engineering.
- McRob2Jan 30, 2017Aspirant
Thanks for the information but, I am not having any issues with the ReadyCloud desktop client today or at any time so far.
My issue is with the invite email link being invalid and not being able to link a web based readycloud remote client.
Hello McRob2,
Is the user entering the account name in an email address? I'm checking if the invite email link is also affected.
