n_damian
Dec 30, 2015Aspirant
Remove devices from android ReadyCLOUD
I added Readynas to ReadyCloud and then I change HDD to new one. After installation system on new one, I added Readynas again to ReadyCloud. How to remove first one from android ReadyCLOUD? Via www ...
- Jan 04, 2016
Hi n_damian,
I have sent you a suggestion to try. Check your PM inbox.
JennC
Jan 01, 2016NETGEAR Employee Retired
Hello n_damian,
What's the model number of the ReadyNAS that appears as rndu2/rndu2000? Is it ReadyNAS Ultra 2 that is running on OS6?
Can you try creating another ReadyCloud account then invite it as a user of rndu2, then log in using this secondary account and see if the same results?
n_damian
Jan 03, 2016Aspirant
Yes it's ReadyNas Ultra 2 running on OS6.4.1.
I created a new account on ReadyCLOUD, then add new user with this solution http://kb.netgear.com/app/answers/detail/a_id/22871/~/how-do-i-add-readycloud-users-to-my-readynas-os-6-storage-system%3F
After log in on new account there is only rndu2.
- mdgm-ntgrJan 04, 2016NETGEAR Employee Retired
Hi n_damian,
I have sent you a suggestion to try. Check your PM inbox. - BrianL2Jan 04, 2016NETGEAR Employee Retired
Hi n_damian,
We are already looking at this issue. We'll keep you posted.
Kind regards,
BrianL
NETGEAR Community Team - n_damianJan 04, 2016Aspirant
Thank You for Your help
- michaelg73Jan 27, 2016Aspirant
So what is the resolution? I am having a similiar issue as well and can't seem to remove the devices I no longer use/own.
Thanks,
-Michael
- BrianL2Jan 28, 2016NETGEAR Employee Retired
Hi michaelg73,
What model and which Firmware is running in your system?
Looking forward to your response.
Kind regards,
BrianL
