AgentANGST-4043
Oct 28, 2025Tutor
Remove ReadyCloud users
linking to --> community.netgear.com/discussions/readynas-use/remove-readycloud-users/2335016
(that is where I first saw the solution posted)
I tried the various commands written at the end of the post linked above.
I tried it in production, like proud, brave, foolish people do and it WORKED!!!
I'm finally rid of the Readycloud users.
It does not let me post the code, so you'll need to get it from the community post linked above.
mv /opt/readycloud/etc/registration.conf /opt/readycloud/etc/registration_tmp.conf
sed -i.bak '/^[[:space:]]*invalid user/d' /etc/frontview/samba/Shares.conf
sed -i.bak '/^#/!s/^/#/' /etc/frontview/samba/usermap.conf
sed -i.bak2 '/[@]/d' /etc/frontview/samba/usermap.conf
find /data/._share -type f -name samba.conf -exec sed -i.bak '/^[[:space:]]*invalid users/d' {} +
sed -i.bak '/@/d' /etc/samba/smbpasswd
sed -i.bak '/^[^:]*@[^:]*:/d' /etc/passwd
sed -i.bak '/^[^:]*@[^:]*:/d' /etc/shadow
reboot
ChatGPT explains it better than me:
1.- ReadyCLOUD disabled by moving:
/opt/readycloud/etc/registration.conf -> registration_tmp.conf
2.- Samba configs cleaned:
3.- Removed invalid user(s) lines from Frontview and per-share configs.
4.- Commented out most of usermap.conf and deleted lines containing @.
5.- Purged @ users from /etc/samba/smbpasswd.
6.- System accounts with @ in the username deleted from /etc/passwd and /etc/shadow.
7.- System reboot
I think you need to be careful if you have AD / domain integration on your NAS, because of the users with the @. If not it seems quite safe and effective. Tadá!
NETGEAR please make OS6 open-source, what do you care? you don't even commercialize it anymore.
- TuratiraAspirant
This works, but you definitely want to avoid it if the NAS is joined to an AD domain, or you’ll break account resolution. On a standalone system though, this method does clean out all the leftover ReadyCLOUD entries.
I've just seen the title, my bad. It should read "remove readycloud users"
I just fixed that for you.
