miels
Sep 29, 2015Tutor
(re)moving backup folder
Hi, I'm using ReadyNas OS 6.2.3-T1741 and ReadyCloud v1.8 On my Win8 laptop I've added a folder "need2backup" to backup (thank you for the option to select a specific folder). This synced ok ...
- Sep 29, 2015
Hello,
I don’t think the backup folder on the ReadyNAS needs to be removed automatically when the backup is stopped as there might still be use for the contents on the ReadyNAS. If you would like to remove it the easiest way would be to use the admin page.
Good point about choosing the backup destination path.
Bye,
Eskender
EskenderNG
Sep 29, 2015NETGEAR Employee Retired
Hello,
Bye,
Eskender
miels
Oct 01, 2015Tutor
Ofcourse :smileyfrustrated:... That way I was able to remove the folder indeed. Thanks!
